Shift rod - shift issue 1988 Yamaha 130
flounderman
Re: Shift rod - shift issue 1988 Yamaha 130
Many thanks Parrfive. I used your method on my 115 v4 and it works. In fact it was fairly painless. thanks Jerry
DjKoKo
I have a 91 V4 115 and wow this looks fairly easy. One question. Do you have to remove the carbs from the Manifold or can it come off as one unit? Looks tougher if I have to take the carbs off the Manifold.
flounderman
I took my carbs off. They needed a rebuild anyway. There are manifold bolts under the bottom carb that may be tough to re-torque if the carbs are still on. good luck
DjKoKo
I just started on it. Did you take the starter off too or not? It looks like it's going to be in the way if I don't.
(Hope you're near your computer often Flounderman. I'm gonna need ya. )
flounderman
I removed the following: carbs, throttle linkage, shift linkage, starter, all electric components, crankcase vent lines, oil injection lines ( label them ), fuel pump, fuel lines, shift rod bracket, intake. Lay intake carb side down with reeds up and cover with clean cloth. Drop lower unit. Take a "big" screw driver and place it behind shift rod bracket and hold it away from crankcase while pulling it up. WARNING do not scrape against the surface where the gasket goes between manifold and crankcase. I will give info on shift shaft reinstall when all this is done.
DjKoKo
Well, I got the shift rod out. I am so glad I didn't do the Epoxy thing (JB Weld) thing I saw somewhere else on the net. That rod was bad at the top too. How easy is it to get the new one in since it's more solid than the old one was and won't bend as easy? The old one I ended up bending in the weak spots without much pressure.
flounderman
It will be the easiest thing you ever slipped into anything !!!!! Take the snap ring off the bottom of the bracket, notice how the ball fits into the "dents" in the shift rod and take apart. You will have 2 nylon washers ,a split bushing, a spring and a ball ( BB ). Clean this stuff put in a zip lock bag with the grommet till you get your parts. Re assemble with the split in the bushing lined up with the grease fitting and the spring in the bracket with the ball in place.
DjKoKo
Well, I went to the parts shop the other day. Figured I'd replace all the gaskets along the way as well. Arrrrgggg....He only had a few in-stock so I have to wait while the rest (include the new SS shift shaft) come in. I'll let ya know how things go once I get the parts.
DjKoKo
I got it back together and it runs great on the muffs. Test run tomorrow. Only thing I did that I can not figure out yet is the electric choke isn't working now. I must have hooked it up wrong or something.
So, for those of you who want to avoid taking the powerhead off and saving LOTS OF TIME, money and headaches. This method WORKS! (Note: I have never done a major job on an outboard in my life before this!)
parrfive
Glad to hear it worked out for ya. There?s lots of tricks out there and its always best to do a search first before trying a repair to see if there?s an easer way.
Check your grounds for your choke problems. Good luck.
DjKoKo
Yeah. My partner in the work didn't hook up the ground. :)
Now that it's been sitting so long, the throttle isn't right. Dies or takes a long time to kick into high. I think it's a stuck throttle but that's for another topic!
tanner1978
would this method of changing the shift shaft rod work on a 1984 3 cyclinder yamaha
nkukea
I think I have the same issue but on a 1999 F100TLR 4 stroke. I took off the carbs & intake manifold, & it does not look like I can get the shift rod up & out like parrfive said. I am assuming that I need to remove the PH. Is it still a pain to do this on this year & model? Also it looks like the circlip at the bottom of the steering tube rusted away,(i found the pieces in the top of lower leg next to water pump), am i correct in assuming I need to change the bushings that are in the steering tube ? Any help appreciated.
dabood
I had 4 different people try to fix my problem all to no avale, I brought it to Auqa marine in Lady Lake, Fl. they used to mech. in the key's, they drilled the bolts so they'd break and pulled the power head. Than they tapped the bolts out.
I don't know all the in's and out's of the job, I paid them. They charged me $1000.00 and I was out in about 10 days. Seeing a motor was $10,000.00 I thought it was a steal. That motor was great after that.
Sorry not much help, I'm a fisherman not a heavy mech., I just do the little stuff. Sorry.
David.
douglloyd
Well my 86 115 shift shaft finally broke. I am going to attempt to replace using parrfives method.
Carbs and manifold not powerhead. Wish me luck.
douglloyd
So far so good Shift Shaft out in 2 Hours going slow. Now I need parts and reassemble.
I'll keep ya posted.
I have pics if any one wants them.
99yam40
Pics would be nice.
Maybe some one will do a sticky showing all needed for doing it that way for the 4 cyl motors
douglloyd
Job is Done! I would say it's easy as pie!
Just came back from my sea trial nice clean shift just like new!!!
Many thanks to Parfive you saved me a bundle.
douglloyd
Pic's as requested
woodworker2001
Where is this shift rod located? Is it something I can see if there are issues?.... I am looking at a 25' Grady white with twin 200 yamahas 1991.... I dont want to end up in a boat which will have major problems, but also dont want to write the boat off...
