tomasz
Thread starter- Joined
- Jul 4, 2012
- 87
This coming up weekend I will have time to resume the search for cause of leak on my alpha one gen 2. I ve build my pressure test so I will test the outdrive, question that I have is- if the cause of leak is shift shaft then should there be water in the gear oil? My oil had zero water in it but gear oil reservoir would be empty after 75 to 90 min of running at 3500 rpm.
