JASinIL2006
- Joined
- Feb 10, 2012
- 5,749
I'm trying to reinstall my Alpha One Gen II outdrive after a transom rebuild. I've been following the manual and I watched achris' excellent video on Youtube.
My problem is that I cannot get the shift shaft coupler to line up straight fore and aft when the shifter is in forward; at best, it's about 15-20 degrees off. The shift shaft lever at the top of the shift shaft seems to be hitting the square fixture on the end of the shift cable.
I'm not sure if I need to adjust the shift cable, or if I'm doing something else wrong. I did reassemble the shift cables in pretty much the same way they came off before the transom was replaced.
Is this a basic shift cable adjustment? Most of the instructions for adjusting it seem to assume the drive is already on. I haven't found any instructions for adjusting it just so I can get the drive back on...
Any ideas?
Thanks,
Jim
Any ideas?
Thanks,
Jim
