Capt Harpoon
Thread starter- Joined
- Nov 10, 2007
- 3
I have twin 2002 115 hp Mercury four strokes on my aluminum work boat. When replacing the lower unit on the port engine, I cannot get the shift shaft coupling to line up. It seems to be off to the side so it is not connected. When I start the motor, the LU is in forward, and cannot be changed to another gear. There is no resistance to changing gears at the helm. I am going to drop it down and switch the LU and helm to neutral and try again. Many years ago, on the starboard engine, I had the same issue. My local boat shop drilled two holes in the fiberglass cowling and used needle nose pliers to line them up during installation (this was in a rush; it is a work boat and I had to work the next day). I now have the same issue with the port engine. I do not want to drill holes again unless I have to. What is the secret to getting the upper coupler bushing to align with the shift shaft on the lower unit? What is the correct orientation of the coupling bushing and the plastic guide donut? The donut just seems to sit there on the shelf with the smooth side up. Thanks in advance for your help. CH
