teddytedted
Thread starter- Joined
- Mar 11, 2011
- 17
:facepalm:
1978 140 HP Mercruiser
1978 Model 470 (pre-alpha) Mercruiser outdrive
After reading similar threads I'm fairly confident that we have "screwed the pooch", but here goes..
We just pulled the lower portion of the outdrive to replace the (shredded) impeller and failed to put it in forward gear. As much as I hate to admit this, when we paired the lower gear case with the upper we forced it a little - the last 1/4" or so was squeezed together by tightening the bolts a little at a time in a "star" pattern. It seemed to suck the lower unit in pretty easily, we didn't have to crank on the bolts very hard to get it together, but from what I've read it sounds like it should just basically seat itself into the upper housing, right?
After assembly we put the muffs on and it shifted into forward fine - reverse has been a little sketchy since before the impeller job but it did go in after a little bit of chatter. When I took it to the lake this weekend it started to chatter going into forward gear as well.
First question: we noticed water was coming out of the shift crank cavity around the shift shaft. Is this normal? Did we bend something or is there supposed to be some kind of seal in there?
