Darol Wester
- Joined
- Nov 4, 2005
- 157
During my inspection of the upper shift shaft, I found that the arm on top is slightly loose. It can be moved side to side while holding the shaft, maybe an 1/8 at the tip of the arm. This probably isn't good I'm guessing. I see there's a screw pin that goes through it that when tighened, it does eliminate the movement. The pin is worn in the middle and probably creating this movement. Would this be the culprit in my not being able to go into reverse? I've looked online for the pin, but all they have is the shaft itself, no pin. Where would a guy find one of these?
Sorry for the blurry picture.
