kramerpage
- Joined
- Jul 26, 2010
- 447
Older Alpha units had a poor seal set-up and the seals would fail from the hot exhaust passing by it.
Mercruiser came up with a new style Shift Shaft Bushing and Lever Kit which improves the Shift Shaft Seal.
If you are replace your shift cable on an Alpha One, make sure you have the new style Shift Shaft Busing and Lever Kit installed.
The Kit helps save your shift cable. If you replace the cable without replacing the seal it will go bad in just a short time.
Is this the kit I need. I am installing a new shift cable OEM.
45518T1?Shift Shaft Bushing and Lever Kit
(for Alpha One
My shift cable slide and shift shaft showed no signs of water entry but I don't want to chance it. I dont fully understand the old bushing seal parts that seem to fail and the new improved set. Seems like I just keep pouring money into this rebuild using all OEM parts.
(for Alpha One
