Shift shaft stabilizer tool
Wotknot
I realize tools are designed to make certain jobs easier, and with that in mind, my question is.... When reinstalling a gen II drive, is it absolutely necessary to use one? If not, does anyone have a certain trick they use in lieu of using the tool? Thank you.
Don S
Re: Shift shaft stabilizer tool
I don't even want to think about how many hundreds of Gen II drives I have installed. Never tried that tool though.
A spot of grease on the roller where it goes to the guide is enough to hold the shift shaft in place to install it. if it falls, you will see it move and nothing will go together correctly. Just back the drive off and put it back in the grease.
Haut Medoc
Yep, what Don says...
A gob of 2-4-C......;)
WillyBWright
I used the tool ONCE. It sat on a shelf and collected dust, probably to this day. POS!
Wotknot
As always, thanks guys.:)
