bill chisholm
- Joined
- Jul 1, 2008
- 23
I have inherited a Merc 8.0 1980 vintage but the lower unit is in a box with all of the water pump parts.
The shift shaft IS NOT in the lower unit..it was removed from the lower unit rather than from the powerhead when accsessing the water pump.
The shift shaft end the goes in the lower unit has a triangular shaped doo dad that screws on the end of it and goes down into the lower unit.
My question....when I push the shaft, with the triangular doo dad screwed on it, into the lower unit what way would the tapered end point and does it lock in to the lower unit somehow. How will I know when it is in the proper postition?
I can't find a diagram that helps either.
Thanks for all of your help !
"Wanting to go fishing"
