harrytrumanagain
- Joined
- May 28, 2012
- 9
Have just re-assembled entire outdrive, adjusted shift cables etc. in an alpha 1 gen 1 sterndrive and (as I noticed as I was attaching lower to the upper) the shift shaft is about 1/4 to 1/2 inch below shift shaft slot. The upper is a new refurbished unit from SEI. The lower is a used one that seems sound in which I replaced the water pump. The shift shaft is the original one (the only remaining piece of the outdrive.) (I have run out boards for decades but am new to stern drives). I realized this might be an issue, and now I see they have to mate to operate properly.
