JASinIL2006
- Joined
- Feb 10, 2012
- 5,758
I was helping a friend install his Alpha One outdrive after he had a new shift cable installed, and after we had the drive on, we noticed something wasn't correct with the trim rams and we pulled the drive back off. As we did so, the shift slide popped off the end of the shift cable core. On the end of the core wore was the crimped barrel end and a small ring of what looked like cast aluminum. (I'm pretty sure the replacement part was not OEM, maybe Sierra?) I'm assume some part of the casting inside the shift slide broke and allowed the core wire to pass through the front of the shift slide.
From what I can tell, this shift slide and core wire must be replaced; I can't see any way to repair the slide and put the core wire back on.
How difficult a job is it to put in a new core wire and shift slide? It looks like we'd just need to disconnect the wire on engine slide, pull it out and slide in a new core wire with a new shift slide. Is that correct? Is adjustment difficult/tricky? I have a Gen II, and the boat my friend has is the earlier Alpha One.
Thanks!
Jim
Thanks!
Jim
