shift
dbotek
:confused:Replaced shift control cable, cannot get it to shift to forward. It will shift to reverse, but when I try to shift forward it comes to dead halt at neutral! This is a pontoon shifter console. I just took cover off. tried to shift, it came to ballbearing in the neutral position. won't go farther. does the key n
eed to be turned on or the motor running to shift to forward? 40hp mariner, had it started,, runs great will shift to reverse and throtle up but still will not shift to forward! This is a quicksilver shifter, the detent screw has been adjusted.
Re: shift
Ayuh,.... Welcome Aboard,...
If you Don't tell Us what you're working on,....
We can't be of much Help......
rickdb1boat
Re: shift
Make sure you have someone slowly spin the prop when you try to shift. Engine off of course..
tashasdaddy
Re: shift
moving to Mercury/Mariner, this is a motor problem
