crazy charlie
- Joined
- May 22, 2003
- 5,602
Hi guys.I have twin 1988 mercruiser 5.0 xl rwc with alpha drives.Recently my port shifter was stiff coming from fwd to neutral.When it went into neutral,it did not make the usual clickThe shifter does not have a name on it.Not a quicksilver.Starting has become an small issue since.I have to jiggle the shifter until it is in perfect position to turn the key.I am having it looked at in a few weeks.Should I assume the problem is in the shifter.Neutral/throttle still works fine when I pull the shift lever out to start it up.Charlie
