ward cleaver
Thread starter- Joined
- Dec 15, 2007
- 174
I am resurrecting a 1970 33hp Evinrude. I found that after removing the lower unit, it was very hard to move the shift rod. It would only go up and engage the prop (or was it down?) and then back into neutral. But it would not go into the other gear. So I removed the lower housing to take a peek inside. Turns out the reluctance to shift has to do with the spring and detent balls. The clutch dog does not want to move over them. I have to use a screw driver to pry the dog over one way and it snaps into position and then pry it back the other way where upon it snaps into the other gear.
Seems like the problem is that the spring is having a hard time compressing. I've lubed it but it is still hard to move the dog over it. Anyone ever have this problem? I will try cleaning out the hole the spring sits in. Maybe that will help if there is some corrosion in there. Speaking of corrosion -- altho this sat for many years without use and had only a little oil in it when I drained it (black not milky white) the parts do not show any signs of corrosion.
