Shifting 75 mariner
weerix
Hello,
I had a problem with my reverse shifting
I just adjust the cable but makes no different
So I removed the underpart of the motor to see there was something wrong
You hear a lot of mistakes when they install a new impeller
I have now put the underpart back and it looks the shifting is ok.
The only thing is that is going very heavy in his forward position and very easy in his reverse
The cable can't be adjusted anymore it's on his end.
Did I make a mistake?
ENSIGN
Re: Shifting 75 mariner
Sounds like the shift rod is a tooth off. Remove the leg and put it in neutral,you should be able to spin the prop both ways,disconnect the cable and put the lever in its center position,Reinstall the leg not moving anything and readjust the cable with the shift handle in neutral.
