D.W.B in Atoka
- Joined
- Jul 1, 2003
- 14
I have a 50hp tracker on 18ft bass buggy with the commander 3000 control box. I took the cables off one weekend and replaced them the next.Bad mistake! What I have going on is the control box is working backwards.It shifts and the trottle works smooth and the motor runs fine good rpms etc. When the control arm is in the forward position the motor moves the boat backward and vice-versa. Question is do I leave the trottle cable where it is, reason being it works when moving the control arm in either direction? It is a pull throttle set up.And can I just change the shift cable to another position in the control box to make work right? I would appreciate any help on the subject.<br />DWB in Atoka.
