shifting disorder on a 1975 50 hp Johnson
Randi_Jeske
I have a 1975 Johnson 50 hp outboard that is having reverse shifting problems. When I shift into F, it goes backwards and visa versa. The mechanic that I had look at it says that I need to replace the L/U. I received the boat and motor as a gift from my father-in-law and he said that the L/U was rebuilt before he got it. My ? is, could the gears in the L/U have been put in backwards and this is causing my problems?
DHPMARINE
Re: shifting disorder on a 1975 50 hp Johnson
First thing is to verify that your motor is what you say it is.If it's older than 1975,different answers apply.Can you post the model number ?<br /><br />Do you have one or two mechanical cables coming from your control box (shifter) to the motor ?<br /><br />Is the control box an OMC one?<br /><br />DHP
Randi_Jeske
Well my mechanic said that the year of the motor is 1975.<br /><br />The model # is 50ESL75B<br /><br />I have 2 mechanical cables coming from the control box.<br /><br />And the control box has johnson powershift II on the side of it.
DHPMARINE
Randi_Jeske,<br /><br />I think you have at least me stumped on this one.Any other info you can give us?<br /><br />Anyone got any hints.Reversing the gears shouldn't do it.<br /><br />DHP
jim_in_day
2 thoughts, one is a prop that is pitched for counter rotation, and the other is even more bizarre. I'm not positive, but the LU may be a counter-rotation LU (for dual motor installations
