yjanray
Thread starter- Joined
- Jul 30, 2009
- 257
Hello again. So not sure if you remember what I've been doing lately, so quick recap. Had a leaky bearing carrier O-ring causing gear lube leak in lower unit. So after a lot of work, I changed out the bearing carrier o-ring as well as the reverse gear bearing. I got it all back togother and all seemed well. Prop locked ccw in forward gear and locked cw in reverse gear.
Finally got the boat cranked yesterday on muffs. It shifts fine into forward and out of forward gear. When I go in to reverse, I feel its kinda rough, that that triggers the shift interrupter, which stalls out the engine. The intermediate shift cable is only about 3 years old, as is the remote shift cable and throttle cable. Never had any problems with shifting in reverse prior to my lower unit work.
So when I was mating the lower unit to the upper unit (which was left on the boat), i had some trouble getting it mated ( as usual), but made sure now to bend the shift shoe or anything like that. I had to drop the lower again to check something, and the shift knob on the lower unit was extremely hard to move. I had to get plyers to move it, as I couldn't move it by hand, like usual. Any ideas where to check besides replacing the cable, because I really don't think thats the issue.
Thanks for your help, sorry for the long post.
