Shifting Issues: Merc 5.7 A1
lmannyr
A couple days ago I backed into a piling (did not hit drive) because the reverse is tricky to get into. When I got in to reverse, It's sticky, stucky, not smooth, what ever you want to call it, the engine reved up enough where it got me off guard and busted up my rubrail (fixed now).
Anyhow, I tried to adjust the cables today and it seems a bit confusing or maybe it was the wrong section I was reading. It didn't seem to do anything.
While I was doing the "adjustment", I noticed that the interupt switch never moved. I was able to push the bracket up or down but it doesn't move witht he shift lever. This was done while the engine was off. The roller stays in the center notch and never moves while shifting.
As soon as I get past the shift point everything is smooth. I reach WOT smoothly etc. It's just geting in and out of gear, mainly reverse.
Thanks!!
Don S
Re: Shifting Issues: Merc 5.7 A1
If the boat is not in the water and running on muffs, the swich should NEVER move. Plus, it should only come into use when coming out of gear IN THE WATER, not going into gear at anytime.
Now, with that information, what is your question?
lmannyr
Why is my shift lever sticky or difficult to move right at the shift point going into gear? Or is it because the shift cables need adjusting?
Just learned something. Thats why I love this forum, always learning something!!
THANKS!!!
Don S
Hard to say for sure, could be a corroded shifter, worn out, faulty cables, who knows, it's had almost 20 years of use. Cables that old can always be a problem, may also be a tension adjustment on whatever control you have.
Yea, I know. I learn new things to. Ain't it neat? :D
lmannyr
So i take it I should replace the cables anyways. I need the 600A Series? How do I measure the length?
Thanks again!!
Ayuh,...
It's My Guess that you only need a New Lower Shift Cable.....
achris
More fish than mountain goat
Part number -865436A02.
lmannyr
Thanks everyone!! GREAT help!!
