phil rogers
Thread starter- Joined
- Apr 22, 2008
- 31
I have a 77 mercruiser boat with a 3.0 engine and an mr outdrive.I adjusted the lower shift cable per mercstuff forum.It shifted good forward-reverse neutral on the muffs at home.I took it to the lake this afternoon.I started it tryed to back up all I got was forward.Even in neutral was still idling forward.I came home disconneted lower shift cable pushed it in and prop locked when turning ccw.I pulled the cable out and It never did lock the prop clockwise.What I am wanting to know is this the lower cable or is it something deeper. Is there anyway to check it for sure without taking it all apart. thank you phil
