Shifting Problem
afrojojo
I have a 1999 25HP Johnson that I just serviced the water pump on. Everything went well on the pump install. After installing the lower unit, I have a small shifting problem. I can shift from forward to neutral fine, but not as well from reverse to neutral. After shifting from reverse to neutral, the prop still spins. If I just tap the shift handle a little to forward it goes to neutral.
I have the shift rod linkage as tight as it will go, but It seems I still need a little more pull and it would be perfect. It worked fine before, so I'm not sure why it's like this. Is there any other adjustment I can make?
The lower shift rod MUST be fully screwed into the lower unit.-----It must not be turned when coupling it up.----2 cylinder or 3 cylinder motor ?
afrojojo
It's a 2 cyl. I have the connectors tightened as far as they go. What do you mean it must not be turned when coupling it up?
afrojojo
After some research I am wondering. Can I adjust the shift rod length by turning it? Is that how it works? If that's the case, then I think I found my problem.
I believe post # 2 is very clear.--------The lower shift rod must be turned all the way into the lower unit !----Then the rods must not be turned when tightening the coupling nuts.
afrojojo
Nice. I didn't realize the lower rod was adjustable. Thanks for your help. I will test it out tommorow.
