myfirstboat1984
Thread starter- Joined
- Jun 8, 2009
- 23
I have a 1984 Wellcraft, with a mercusry mercruiser inboard/outboard, 4 Cyl, 140 HP, 3L Engine. Several times over the last couple months, the boat has slipped out of gear. Before, I was able to get it back in gear, but this time, I was not. I am not able to get any forward or reverse now. Here's what I know...
-Drained oil. There are small medal shaving in oil. Enough to be noticable. This oil was changed a month ago.
-With engine on, from control panel, shift to foreward or reverse, and there is absolutely no gear sounds at all. No grinding, but the shift cable is moving and the linkage is intact all the way to the lower unit.
-With the engine off, shift to forward. I cannot turn the propellor in the reverse direction, but I can turn it in the foreward direction easily. When I do, there is a click noise about midway up the lower unit.
-with the engine off, shift to reverse. I can turn the prop both directions easily, and the click mentioned about doesn't happen, but there is some very slight clicking at the lower part of the unit, near the prop.
- Maybe related?? The empellor is no longer pumping any water through the engine (using muffs).
Any thought are welcome.
