Re: Shifting Problems Merc 150
Charlie and I think a little alike.. Here's how I would go about it.
At the engine end of the cable, look at the rack where the cable end lays in and connects the the shift rod arm. Remove the spark plug wires. Disconnect the shift cable at the engine and manaully shift the engine into neutral. Verifiy by turning the prop that the engine is in neutral (this is why you disco'd the plug wires, safety first).
There is a F-N-R cast into the shift cable rack. Make sure the pointer is aligned with the N when the lower unit is in the neutral position. If it is, then your mechanic probably already did this and it is probably a bad dog clutch.
If it isn't, with the engine in neutral, drop the lower unit far enough so that you can re-align the shift rod splines 1 spline in the direction is all it needs to go. It's not going to be off by more than one spline. It can be easier if you have a helper to watch the pointer while you align the rod. When it's good, bolt it back up. Then put the plug wires back on, put it on the hose, fire it up and check for proper shifting.
If the problem persists and a re-alignment was needed, then the dogs on the dog clutch are probably badly worn due to running it while it was misaligned. They have finally worn to point where they don't hold anymore.
The cost of repairs can vary widely but you can start at around 400.00 if everything else is still in good shape. It is sometimes more practical to replace the entire L/U with a fresh rebuit one for between 750.00 - 1275.00. Your mechanic may have a used one for much less or you might try your luck on eBay.
