gabe33366
- Joined
- Sep 4, 2012
- 44
So this is on an alpha 1 Gen 2. I just reassembled my lower unit and I'm pretty sure I messed some thing up. In forward and reverse the prop spins by hand with a clicking click sound. In neutral the prop spins freely with less resisance. The prop shouldn't turn at all in gear right?
Before I took it apart I put the boat in forward and turned the prop by hand to confirm it locked. I removed the prop and dropped the gearcase.
Before reassembly I confirmed the shifting lever on the gearcase and the fork in the upper half were both straight. Also I turned the driveshaft clock wise and the propshaft also turned (forget the direction).
I'm assuming something didn't go into gear like I thought it did and I'll have to drop the gearcase again.
Any help would be greatly appreciated. Thanks
