rodeohand28
Thread starter- Joined
- May 3, 2009
- 3
i have a 1990 sea ray that was in a little accident. I had to replace the outdrive with a used one. i believe from reading that it is generation I. the motor in this boat is a 5.7. the boat shifted fine with the first outdrive but since replacing it shifts fine in foward but is at a very high rpm when going in to reverse. also when reving motor out of gear you can hear the outdrive ticking like it is trying to shift into gear. i did notice when i put the new outdrive on the channel did not line up perfectly if that helps. i hope it is an adjustment and not a bad outdrive. any help will be much appreciated and if you need more info let me know. i am a new boat owner so bear with me lol
