agallant80
Thread starter- Joined
- Oct 25, 2010
- 2,328
I not sure if I can accuratily describe my issue without more detailed photos but I will give it a shot.
The pole on the trailer is not level with the other trailer beams. When the trailer is level the front of the beam is 18.5 inches off of the ground and the rear is 18.5 but the thoung is about 26 off of the ground. This is causing issues getting the trailer to ride level. I keep on moving the hitch higher and higher which causes issues with the jack reaching the ground.
The pole toung connects to the trailer frame via 2 brackers (one on each side of the frame) with a single bolt and a plate in the back that connects the two frame sides and pole toung togeather via u-bolts.
What I want to do is loosen the ubolts on the toung pole and add some shims under until the pole toung is more in line with the trailer frame.
Does anyone see an issue with this? I have attached a photo to help describe what I am talking about.
