lonewolf41
Thread starter- Joined
- Jun 28, 2013
- 174
In replacing the shift shaft/piston seal on my SX-M1, I found out that the eccentric piston was badly pitted right at the seal and I am having to replace it. I had to remove the stop bolt from the old piston to put in my new piston. There is a procedure for shimming the stop bolt using special tool 3850057. Is that the only way to set everything up is by buying the special tool? If so, I wonder if it would be better just to take it to someone to have them set it up. It doesn't look like it will take very long to do.
TIA,
-Keith
TIA,
-Keith
