Shore power breaker amp size!?!?!?!? Help
tbone999
Hey guys I'm half way done new floors and stringers in my boat, with everything gutted I want to jnstall shower power with a few plugs one in the cuddy one by my dinette table set, if I add these two outlets and want to install a battery charger how many amp on my fuse panel do I need, staying on the boat I'm looking to run a hot plate, coffee,charge ipad etc I'm looking to buy one on ebay so any help on what to buy and what's not Chinese crap would be great
Cheers
alldodge
Most all shore power connections are 30amp. They all use the twist lock connectors then feed tat to your panel. Run a couple 15 amp breakers off it to feed your other stuff. You can run a 20amp side without any issue. Don't any need for more then that with what you have listed (Hot plate and coffee pot is the heavies).
http://www.iboats.com/Replacement-I...0700801--session_id.026703206--view_id.133803
Then put in a panel
http://www.iboats.com/Marine-AC-Dis...0700801--session_id.026703206--view_id.469690
tbone999
Right on thanks very much alldodge I have a inlet already along with some sockets I got on ebay that came out of a beneteau, so on that link you sent me the blue sea 8077 would work for my needs?? And clearly I won't be installing this myself I'll leave it for a pro just trying to say some cash where I can
Thanks again
alldodge
You can put this in your self, but understand if you decide not. The better part of a man is to understand their limitations. Very few men will actually admit they have an issue and then explain to the insurance company what happened.
The 8077 should work fine for your configuration
JoLin
Talk to your pro about any additional stuff you'll need, like a galvanic isolator. I understand you're trying to save some cash, but I'd personally be a little leery of buying used electrical equipment. I installed air conditioning in my boat this year, along with a new and separate 30-amp shorepower circuit. It wasn't cheap. I used this panel, which includes a 30-amp main breaker and 2 branch circuits. I'm using one branch for the A/C. The other is reserved for a couple of additional 115-volt outlets I plan to install. You might want to put your outlets on one branch and the battery charger on another.
https://www.bluesea.com/products/1206/120_Volt_AC_Main_+_2_Positions
My .02
