1986 aq131a with 275 out drive.I am looking to replace the prop but how do you tell if it is a short hub or a long hub? Mine has the cone with the plastic washer and a allen bolt holding it on. Thanks.
I think a short hub shaft cannot use a long hub prop, but a long hub shaft will use a long hub propeller but can also be fitted with a short hub prop sing the proper hardware?
