shorting out
socketholder
I need the wiring harness with the red plug for an 84' 35 hp johnson motor side. I find them on ebay listed for other size motors like 80 and 100 hp.
and also from the 1970 motors will all of these interchange with mine? if not. what yr and size motors will?
thanks.
the + lead (inside the started) on one of the brushes in the started broke lose
would this cause the plug to short/burn out? also burnted the wire on the starter solonoid.
the motor will not fire when the plug is connect, however it will run when its dissconnected
