capslock118
Thread starter- Joined
- Apr 27, 2009
- 249
Hi there,
Long time reader, first time poster (ha)
so...I have two questions:.
Note, I am not in any way knowledgeable about engines other than how to replace spark plugs, add oil and gas.
Engine: 1990 Mercury 2-stroke 135 hp
Is it normal to see exhaust spitting out of the center of the prop?
second (more important question with a backstory)
backstory:
end of last season i bought a boat. I took it out for the first time and the water impeller failed. I know I am suppose to turn off the engine immediately. I let it cool but since i was close to home base I decided to try to push it home. Half way home driving about 5mph i start to see signs of overheating (this is well past the point where it starts beeping at me) i.e. smoke - not fire smoke just the type of smoke you would expect from something getting really hot. End of the story - i got towed back.
So now I begin to summerize the boat after having a place winterize it for me. I turn the engine on and its certainly billowing white smoke. I have tested the engine about 3 times for about 30 seconds each thus far.
I have read in the Seloc repair manual that this can be an issue with a cracked powerhead or cylinder where the water from cooling is leaking in causing a bad mixture and creating the white smoke. I have also read this could just be an issue with bad o-ring sealers that keep the water out (which could be the case with an engine that overheated?)
Question(s):
Knowing all of this, could we narrow down the possible issues or have I already found as much as I can before taking it in? is there more information that i could give? Is 30 seconds even long enough to indicate anything? Ive read that this could just be the engine warming up from being stored for the winter for the last few months and letting it run for a few minutes is better (but i need to figure these things out first because i am afraid of damaging the engine even more)
I have not done a compression test yet and I would probably have the mechanic do that as I am not confident in performing one.
The long and short of it is, i know this very well could have been a huge mistake on my part when i overheated the engine, I am prepared to take it in this week to get it looked at by a mechanic, however I would like to go in with some additional knowledge that I have not picked up from anywhere else.
Thank you for your time everyone.
regards,
-joel
backstory:
Question(s):
regards,
-joel
