Re: Should I? 94 Four Winns Freedom 170
I have a '93 Freedom 180. It is a foot longer but other than that the same. Max hp for mine was 130hp but FW did sell the 94 170 with a 140hp according to their website so you should be GTG on that. I do about 40mph with the 115hp on mine. 60+mph on that one which is a foot shorter and with a 140hp would scare the
out of me!!!! But that is just me.
Some thoughts/observations.
The ski locker lid, fuel tank cover, and seat bases are the only wood parts exposed on my model. I assume this one would be the same. The ski locker lid was large and wide and flexed. Mine was rotted and I replaced it with new 3/4" PT but it still flexes. I can understand why he put 5/4 on there. I also had to replace the fuel cover as it was completely rotted. Be sure to check that.
The vinyl is "firm" but not hard on mine and the stitching is coming loose in several areas. Not a big fix to restich it if you are willing to put in the time.
I cannot speak for the missing cover on the back as mine does not have that.
My rig also suffers from what I will call sloppy ride quality. See my other posts on that subject:
http://forums.iboats.com/showthread.php?t=310913 That may or may not be a concern for you.
Other than that, I can't complain. The rig is pretty low slung and a little tightish (I'm a pretty big guy) but overall I cannot complain.
I paid $1700 for mine but it has a 115hp, is a year older, and needed a lot of work. Nothing structural though, all cosmetic.
Good luck and be sure to sea trial it before making your decision.
