snake91876
- Joined
- Jun 25, 2007
- 211
Have unresolved issues with my boat. it busts up at mid to upper rpms. Changed carb to a new one and ran slightly finer but is busting up and popping back at mid to uppper rpms. I dont know if i have a fuel delivery problem or ignition problem. are points efficient when set right or should i just opt for the electronic to rule out that issue. I dont know where to go the boat busts up worse when i put a higher pitch prop on and create more load. Boat idles and cranks perfect just when underway at mid to upper gives me the problems. I noticed when working on carb when i take fuel line loose the gas is not at the top of the line , should it hold gas to the carb.
