2001 Johnson 150HP with a 14 3/4" x 19" SST stainless prop.<br />21' fibreglass boat, deep V hull (22.5 degrees)<br />AV plate is about 1 1/2" - 2" above bottom of hull.<br /><br />With a light-medium load (three people plus full tank) I can get about 5000rpm @ 44mph (GPS) at WOT with motor trimmed right out. Very light load (just me) I can pull 5200rpms @ 48mph (on a good day with the wind behind me
<br /><br />Motor is running sweetly and is mounted in second highest position, i.e. I can only go up one more hole. No ventillation. Boat used for a variety of purposes - general crusing & some skiing.<br /><br />Dealer says this is fine but I figure some more revs would be better for motor. Motor is already mounted fairly high and I might risk ventillation if I raise it to highest slot.<br /><br />I may be able to source a 15" x 15" SST prop at a good price. Would this be going down too far. A 15" pitch on a 150 seems very low. What do you think?
