phatwake360
Thread starter- Joined
- Oct 26, 2009
- 21
drained the carbs on my merc 90 3 cyl 2 stroke (93)
to winterise it i ran it up on muffs discoonected the fuel pipe waited until i started to die the fed it loads of fogging oil though each carb. then eventually it died so i removed the plugs and liberally coated the cylinders with fogging oil again the turnd the engine over buy hand, to proper coat the walls. but a reliable friend of mine later told me i should have also drained the float chambers on each carb!!!! my boat is in storage for the winter so do i need to go drain the floats to make sure or should it be ok??
