Should I open the floor?
pat72
Re: Should I open the floor?
One last thing. The boat was built in 1961 so how can I make sure that it's not going to fall apart on me. Sound stupid, I know, but it's 49 years old!! The hull looks good from the outside but how well does fiberglass age? Can it crack without any warning? What should my untrained eyes look for to make sure that I don't become shark food in the next month or so?
Yacht Dr.
Hate to say this ( Im the black sheep though ) looking kinda like a Particle board deck to me..
Those "stripes" at first might look like Unidirectional glass..but..more likely now looking like carpet lines.
3/4 " Solid fiberglass deck ? It could be the pics though..Thats seems to be Too much glass for the size of the vessel m8..
Warping of that much glass is IMO very unusual..
Got some more Pics of were the deck is glassed to the hull ?
YD. :)
Bob_VT
Okay a black sheep may not be a lone black sheep in this case..........
I am really not sure what I see for decking material in the picture. It appears way to granular to be fiberglass alone.
My jury is out on this one too. Got any close up photos?
pat72
I attached a few pics of the 2 pieces I cut. It's 1/4" thick.
I'm leaving town tomorrow until monday so I won't be able to reply but please keep posting if you see anything that I should be concerned about. As I said it's a 49 years old hull so I rather know now than find out a few miles from the shore that I should have worked on it a little more...:eek:
Mark42
Looks to be some type of composite deck. Molded as one piece (judging from the tapered edge) and glued and or glassed in place. Its obviously got CSM on top, and at only 1/4" thick, its not ply or fiberboard, they would not be strong enough.
My guess is its an early composite designed to prevent rotting floor.
If its not heavy stuff, I might be inclined to lay a few layers of glass on top of the entire deck and call it a day. Otherwise, pull it out and go with plywood.
Woodonglass
I agree, that looks like glass to me, but not much there. Not sure how I would fix this one. Depends on how much SAGGING is going on. HMMM. I'm thinkin on this one...
I'm just sayin...:D
Yacht Dr.
I dont know were the new wood came in..
The pics are looking kinda ... erm.. inconsistant with the posts.. it was all glass .. now Im looking at some freash wood there..
Btw.. taking pics at 45 deg. angle to the thickness does not help..I still dont see 1/4 inch thick in your cuttout.
IF your edges are really that thin ( still looks like 3/4 inch thick :) ) .. then its time for a re-deck.... sorry m8..
Got some pics of where your deck meats the hull ??
YD.
Mark42
YD.
Put your glasses on old man. That ruler is measuring 1/4". And what "fresh wood" are you referring to?
http://forums.iboats.com/attachment.php?attachmentid=72824&d=1289539239
twkjr 1250
you can try cutting deck right where the crack is to see if something is wrong under that spot . also see if the stringers are secured to the hull bottom . if not you will need to tab them back down
Hoggar
Hi Pat.
I would Suggest you pickup a copy of Runabout Renovation, Lots of great Info in there.
You could seal up those holes with a sheet composite. Find some thing
with no wood in it you have a hull with no wood in it you should keep it
that way.
