I have repaired owned and dealt with the same line of engines for yrs. also I just purchased a older 63 Electra shift 40 hp the shift solenoid are similar but use bat+ to change shift direction. Hydra shifts like yours transfer fluid pressure to shift. still very similar to yours Very dependable engine. Simple to repair if you understand the technology. I also have a couple lower ends for the hydra shift 55 and 60 no if their still in my parts shed. The 50hp Electra shift has a different drive shaft spline. Almost all the parts I've needed were found on ebay.. Any questions you have I'll be happy to help. Enjoy hearing from a young person eager to learn save money and take on a older project.Update: I went ahead and took my chances by buying this motor. I paid $235 and it came with a supposed dead battery that is actually a good battery which is a plus. I can post any pictures requested if it helps diagnose any issues. I plan to start by just tearing the old wiring harness out and seeing what electrical wise needs replacement. That and I’ll rebuild the carbs and the seals and impeller in the lower unit. Anyone know where I can find the model number on this unit? I hope it’s not missing.
Exactly!! However similar that the shift switches add and removes b+ to operate the magnets on the Electra and the hydro changes the B+ to change fluid pressure flow to engage dogs. Simple process. The shifters are not interchangeable!The shifting on the old ELECTRAMATIC is totally different from the hydro-electric shift units.----The electramatic uses electromagnets to pull on a spring , no clutch dog.-----The hydro-electric use solenoids to operate valves , to direct oil pressure on a shift piston.----The shift piston moves a clutch dog.
Yes. They stay engaged in forward until power is applied to switch between neutral and reverse. My older neighbor didnt refill his lower unit few yrs back tried to back off trailer lol took a few rams of his trailer crank before realizing he needed to call me..No damage done but wishing had a video of him. Very confused..But the HYDRO -ELECTRIC does NOT need battery power when in forward gear.-----The clutch dog spring puts them in forward.-----The electramatic needs 12 volts to stay in forward all the time.
I had 99% blockage of my arteries in my heart opened up now but will be few days before I can get home and out to look for my lower ends..Brokenback said:
In my case I enjoy keeping any old mechanical thing going anyone can buy a new one takes a speacial desire to enjoy rebuilding old.. Especially at the age of Wesley 35601. To take the task on..ahicks said:
Regarding the question to purchase an electric shift, even one that works, WHY?
Unless there's something unusual going on with a particular engine (an emotional attachment for instance), there's too many easy to service/maintain mechanical shifting motors around for me to even consider an electric.
I agree 100%. And that's after owning 2 of the blasted things.Regarding the question to purchase an electric shift, even one that works, WHY?
