Should i replace cable
krobbins
I bought a new replacement cable and when i fed it thru hull and started tightening the nut the whole cable twisted like a pretzel (before the inner core was added), it did not put a kink in it but just bent it some! Should i bite the bullet and buy another cable and avoid this potential mistake before i put it all together?
bamadave
Re: Should i replace cable
No mention whatsoever of what you are working on. Help us to help you by telling us you are working on.
JustJason
I'd straighten it all out an slide the core in. If it goes in easy go with what you have. If it fights you at all going in then replace it all.
