Should I replace the bearings?
kryck
Hi everybody
I'm O.D boring my 50 hp 1998 merc since the two mid cyl's are slightly oval/out of round. Questions for all you engine experts:
1. Should I rebore all four cyl's although the top and the bottom seems just fine (when measuring)?
2. Is there any third party manufacturer of pistons and rings or do I have to buy original?
3. Should I replace the rod bearings and the crank shaft bearings? How do I know if they're good/bad?
Thanks
kryck
Re: Should I replace the bearings?
Forgot to mention that this is a four stroke ELPT. I've found plenty of third party pistons for two strokes (GLM, Sierra, Mallory) but none for four stroke pistons.
Faztbullet
Yes...reason is balance issue and 4 stroke.....
Not at this time are aftermarket pistons offered,you have to go OEM.......
Yes you need to change main and rod bearings, you will need manual to get the tolerances on the colored bearings(brn,blk,blue) It better to have a machine shop measure and set this up for you as its a pain if you dont note where colors/bearing came from.
