Hi All,
I have a lot of corrosion on the starboard manifold. Previous owner said he replaced risers and manifolds ~3 years ago, but I think he only replaced risers. I NEED to replace the manifolds and possibly the risers. I think there was a leak between the manifold and block which caused severed corrosion. Three bolts are rusted out and the bolt heads are too corroded or rounded to remove. Hopefully drilling them out will work. Any suggestions here are welcome.
But, my main question is should I replace the risers or can I get away with another year or two? These are all Mercruiser parts. I plan to buy Osco. Hopefully using the Osco manifold and gasket and Mercruiser Riser is compatible. The other side is not pulled but appears to be in slightly better condition.
Thanks
Thanks
