- Joined
- Jul 18, 2011
- 19,256
Re: Should I replace These Risers?
Just notice the pictures of the cylinder heads . . . in answer to your question . . . On the 454 engine the exhaust gasket traps water and hold it against the cylinder head so that everything can rust. I'm not sure what you can do about it, except keep after it.
Yours look good compared to what my engine looked like when I tore it apart last fall. The head bolts were a socket size smaller from the rust flaking them away. I barely got them off without snapping the head of the bolts.
Anyway, your cylinder heads look OK and are quite fixable with a wire brush and some paint as you mentioned.
BTW - you are lucky, I had to pull my engine in order to get the manifolds off. The bolts were pretty trashed and I had to mill the heads of 3 bolts off. The others came with a bit of work.
Finally got the manifolds out. 16 bolts total: 11 came out normally. 3 came out with a bolt extractor. 2 needed to be drilled out. About two hours of drilling per bolt. Really should have pulled engine instead. Destroyed all my bits. Don't have a dremel and couldn't get a right angle grinder in there.
One exhaust port had a tiny bit of rust inside. Some exhaust ports were dry, other were wet with a black grease/oil
Questions:
- How did this rust occur? Now that I realize there is no water jackets between block and exhaust manifold, why is the head in such bad shape? It doesn't appear there was a leak from manifold-riser gasket.
- Should I attempt to replace the 2 or 3 rusted bolts on the head? If I leave them, they will just get worse.
- Do you recommend taking a wire brush to try to clean up the head/block and then re-prime and paint with Rustoleum spray cans?
- Having trouble finding what bolts those rusted ones are. Engine S/N: 0K035983
- Do you think it's possible these are the original manifolds? Boat is '97 with ~500 hours.
Thanks!
