snake91876
- Joined
- Jun 25, 2007
- 211
i have an alpha one outdrive if i grab the prop i can wiggle it in and out alittle bit is this normal
not sure what the outdrive is on it
Thanks for the info, Is this a alpha 1, 2 or what? Not sure how to tell. also whats the gear ratio and are they all the same on each alpha model? I'm going to drain the fluid today, we ran that boat 4 hours yesterday so I'll see how bad it is. I am going to pop the top cover and take a look, also check out the coupler if I can see anything. Do you think this is the lower gearset or the upper? I've had outboards apart so I hope this is similar. The rear engine mounts look like they are missing a top rubber bushing, the motor seems to move around a bit. I may use some bushings I have laying around to tighten those up.
