Should water be coming from this area?
jcw74801
Engine is 150EXEDB. I installed a new water pump on this engine for the first time. Used a full kit, not just an impeller. Also installed new thermostats. Running it on the muffs we have very strong telltale flow but also water is pouring from the area circled in the photo below. I don't know if it was doing this before the water pump change. And I don't know if this might be normal.
thanks
1946Zephyr
Re: Should water be coming from this area?
From what I heard in the past, that is normal.
jcw74801
Awesome, thanks guys.
the machinist
Cut down you water flow from the household water line. You have more water pressure on muffs than normally with the motor's water pump & the cooling system can not accept it all so water is blowing past the water pump outlet grommet.
