shurhold polisher
sdw41lite
This spring I need to rub out and polish my boat. I need to buy a buffer. I do not want to this by hand. I have reading on alot of threads on here so see what people were using and what products they are using {rubbing compounds ,polishes, and waxes }. Has anyone used the Sherhold polisher and there products. I have read some good things about this.
oops!
Re: sherhold polisher
hi.....welcome to iboats....
i use one for a living......i dont or have never heard of that tool or the product........i think that speaks for it self.......they have been in business for 40 years...and the pros dont know about them. possibly in the states....but not here in canada.
i googled them......the polisher looks like a toy to me.....i use a big makita.....vary speed. you need a vary speed due to the nature of the materials you are working on.....slower for some....faster for others.
harbour freight has a good vari speed for under 70 bux.
as for product ....most of the pros use 3m products... i use farecla......an industry standard in canada
sdw41lite
buffers
buffers
I need to buy a buffer to do my boat in the spring. What kind are you using and how do I get a great looking shine. I would like to hear how you do your boat and the products you use. Thanks
NHGuy
Re: buffers
Re: buffers
How good or bad is your finish? How about pictures?
90stingray
Re: buffers
Re: buffers
I use the cheap-o buffer from harbor freight. It was like $30. It has adjustable speed. Works for the boat... but smells like it's going to burn the motor up the entire time :) I also use 3M products. For a chalky gel coat, i would use something that has a grit you can feel in your fingers... these heavy grits usually don't finish 100% glossy. So usually you step down to a finer finish then finish it with a quality wax.
NHGuy
Yup, get a variable speed polisher. Start to do some reading on finish treatments. I have an really old black & decker 2 speed polisher that I got in the 70's when I needed to do over a car. I don't need it very often, but it still works fine. I even retrofitted it to grind some paint on my daughters teenager sh..box.
oops, I digress.
My boat wasn't all chalked, but I wanted to get it all the way shined up. So I had to wet sand. When I got done with that I used some Meguiars Ultra cut 105 compound, then some 3M polishing compound ( the tan stuff) then some good Meguiars carnauba wax. Looks really good.
Learn the right way to use the buffer.
If you get a buffer that uses pads that are tied on to the buffer disc, tuck the strings in before spinning the machine. Start the wheel before putting it on the boat and remove it from the boat before shutting it off.
Always keep the contact area moving when it's in touching the finish. Use the buffing wheel on a low angle to the surface you're working. There is flexibility in the backing disc. So you can use the springiness of the disc to determine how much contact your pad makes. Don't put the center of the buffer down on the work while it's spinning, that causes swirls. And don't buff onto corners, that burns the finish, so buff off of corners. When you get to spots that the buffer won't reach, do em by hand with a cloth. For really tight little spots you can even put some compound on your finger, just rub it in and wipe it off.
Don't lean too hard on the buffer, just make good contact to work the abrasive against the surface. You eventually will "feel" when it's right. Low speeds are good for most things. I mainly use high speed when there's a lot of product on the surface and I spread it to work a larger area. I do that with lots of buffer movement along with the high speed. I also sometimes use high speed when removing product with a light pressure and a clean pad.
When you are done, it always takes a couple more touch ups on missed or uneven spots. And when that 's done it never seems that I get all the missed and oversprayed polish off the til I've gone over the boat a few times.
Hint, mask off the outdrive with a big trash bag, anything else that the buffer could spray might be smart to cover too. Cover things like speakers, gauges, radios windows and vents.
It's work, but I find it rewarding cause I take pride in my stuff looking and acting right. I hope your boat comes out great!
Don S
I merged your 2 threads together, please don't start multiple threads on the same subject.
sdw41lite
Thanks guys for your input. I dont think I want a rotary. I heard this is for the pros. I have never used one I dont want to mess my boat up. The variable speed polisher sounds like the way to go. I am going to try and post some pics. I tried before and it wouldnt let me, the finish is really dull and I need to paint the bottom this spring.View attachment 123294 ok The pic is here
sdw41lite
Thank You for the help NHGuy
rfdfirecaptain
Yeah thanks NHGuy... great advice.
Definitely go with the $40 variable speed buffer from Harbor Freight. I found that tool to be perfect for the job, but when I purchased my pads I went to a local body shop supplier. And I used 3M products.
Ernest T
I use a Porter Cable 7424XP polisher to apply polish, compound, wax, or whatever to the boat: http://www.autogeek.net/po.html It is very similar to the Shurhold polisher in that it is totally safe for the finish. I got mine at Autogeek. They usually have the best prices. This thing will completely eliminate swirl marks. I used it on my 8 year old car and the finish looked better than new.
To buff I got the cheap Harbor Freight system that others mentioned: http://www.harborfreight.com/7-inch-variable-speed-polisher-sander-92623.html Just be sure not to crank it up too high and it works great. I got the shiniest boat at the marina.....and that is according to the guy that does the detailing for them.
sdw41lite
thanks everyone for the help, from what i have been reading 3m products are used by alot of guys and mc guires and the harbor freight buffer for 40 dollars.
jayhanig
Apparently I'm the only one here who's actually used a Shurhold polisher (spelled with a "u"). Trust me, it's not a toy. This isn't the kind of tool I'd buy for my brother in law; it's the kind of tool I'd buy for myself. If there's a negative, it's that it's heavy. But it's variable speed (2500-6500 rpm), very heavy duty, and it comes prepared to work in a wet environment with a GFCI plug at the end of its 20 foot long cord. I have the $150 kit.
sdw41lite
Thanks jayhanig I have read alot of good things about the shurhold polisher, does it work good and what do you think of there rubbing compound buffmaster and there polish, does your boat shine really good have you use it
sdw41lite
Hi Ernest I think I am going to get what you have. What kind of pads and compound, polish,and wax, do you use. From what I am reading you cant wax and buff your boat with the porter cable. I am guessing it spins to fast so, I will to get a cheap buff.Thanks for your help
I did 4 boats this summer with a harbor freight special
Ernest T
The Porter Cable 7424XP is nearly exactly like the Shurhold unit (2500-6800 variable speed). This is what you want to use to put on the wax, polish, or compound. This unit has the dual motion and if you apply too much pressure it stops rotating, so it is totally safe. Then I use the Harbor Freight unit to buff on a low setting. That is because I have found the Porter Cable unit to be too slow with getting the wax off. The pros use a unit like the Harbor Freight unit that spins continuously to both apply and remove what ever they are applying to the boat but you have to be careful, because you can burn the finish.
I got this system from Autogeeks: http://www.autogeek.net/poca74pofcop.html. It has a couple of different pads to use depending how aggressive you want to get. I use the black pad to apply the polish to the boat, since I didn't need to be real aggressive.
I originally bought the Porter Cable for my car, so I got one of the car polish systems with it. What I've been using on my boat is MeGuiar's Cleaner Wax: http://www.amazon.com/Meguiars-M5032-Boat-Cleaner-Wax/dp/B0000AY50X. This works great if you have light oxidation and stains. The last time I tried Starbrites product on the recommendation of several people on this site: http://www.amazon.com/Star-brite-Step-Heavy-Cleaner/dp/B002E9E1HS/ref=pd_sim_auto_2. I couldn't tell much difference in the shine, but the Starbrite with PTEF was a little harder to buff off. It is supposed to last longer......I'll find out next season. If you have lots of oxidation you may need something like this: http://www.amazon.com/Meguiars-M673...=sporting-goods&ie=UTF8&qid=1322421955&sr=1-2
sdw41lite
Thanks Ernest for your help
jayhanig
I have bought their polish but haven't used it yet since I still had some other stuff. I have buffed out my boat twice with Starbrite Polish and the Shurhold buffer and got excellent results both times. Next year when I do it again I'll be using the Shurhold polish and will be able to compare it to the Starbrite. My boat is dark blue and the buffer gets rid of any chalking that develops over time really well. You can see your reflection in the gelcoat when I'm finished.
