AK_FIREDOG
- Joined
- Jul 9, 2008
- 3
My 1991 Johnson 120 w/jet unit is really starting to cut out at higher rpms (5000-5200). I have replaced the fuel pump, checked all fuel lines for leaks and changed out the sparke plugs. I set the gap at .30. It also cuts out under a load like, when I'm pulling a skier or a tube. Its seems to be ok when its not under a load. When it cuts out it drops rpms alittle around 4200, no change in the engine sound, however the throttle will be wide open and only turning 4000-4200 rpms. Now when I bring the throttle back to neutral then forward again its ok for a while, depending on the load and t&t. If I trim the motor up createing less load, the motor gets on step with out cutting out. I'm thinking about changing the sparke plug wires and coils. What do you guys think?
