Side mount control box Suzuki DF80 2009
stylesabu
Re: Side mount control box Suzuki DF80 2009
I moved mine on a dt75. no problem.just make sure your cables will be correct length
GonzagaCRO
Do you have a manual of the control box?
I can`t find it anywhere...
Is it possible to move trim switch to the left side?
stylesabu
my trim switch is part of throttle arm
stylesabu
why have you already opened control box? If so disconnect both throttle cables from motor.this will make putting control box back together much easier. the trim wires run through throttle handle. if you notice the three mount holes on both sides of control box are counter sunk for this reason. hope this helps
yes you can, have done it a good few times on DF90/115 the DF80 has the same control box
