Re: Sides inside boat calling Aristotle
Realgun,<br /><br />That is a lot of work you put into that boat. It is looking solid. I suggest that you decide what seats you will have, then purchase matching vinyl and high density foam padding and try to replicate what was in the boat originally. 3/8 ply is a little thin for seating. 1/2" will work as long as there are some cross bracing on bench seats so they don't sag when stood on.<br /><br />Go to the library and get a book on upholstry. Simple side panels, even in multi color vinyl is fairly easy to do. You probably already have a staple gun, get some stainless steel staples and have at it!<br /><br />You can save a few bucks by running carpet up the sides of the boat where there are no bench seats. I think it would look good as long as the seats are nice and contrasting. Like white seats/blue carpet or blue seats/grey carpet or cream seats/beige carpet.<br /><br />If you do use vinyl, buy the heavy weight and it will last many years.<br /><br />Another thing to consider is heavy ribbed sheet vinyl for the flooring. Easy to clean, wears well, water proof and cheaper/tougher than good marine carpet. Just a bit hot on bare feet.<br /><br />Just some thoughts. Good luck and don't forget to update your project photos for us.<br /><br />Mark.
