Signature
Bayou Dave
I noticed that signatures are not showing when a member posts. Before the change over in June or July most members, including myself, had their signatures with text or photos showing beneath their posts. Is there a setting that I have missed or does iboats just not show signatures any longer?
Tnstratofam
Go to profile, edit settings, account, edit post signature. You should be able to recreate your old sig, or make a new one. You also have to check to make it visible I think.
Bayou Dave
Perfect!! Thanks tnstratofam..............
Tnstratofam
If you aren't seeing other peoples signatures make sure in settings that you have checked to see other peoples post signatures, as well as user customizations.
Bayou Dave
Perfect. Nice looking Rinker by the way.:encouragement:
Photo is from 2 years ago. Got it for what I feel was a good price of $1800. Everything is original. Has the 4.3L 175hp motor that runs great. Only 2 small slits in the upholstery, solid transom and floor. Had the outdrive gone through with new gimbal bearing and all bellows.The seller had all the paperwork from the day it was ordered from Rinker. It even has the original trailer. Spent all but the last 3 years in fresh water.
