Sikaflex 291, how fast to cure?
BoatFisho
How quickly does sikaflex cure in, the 100ml small tube? I know there is a fast cure version, but dont want to spend that much as its a little job.
BoatFisho
Very thin coat attaching rubber to gel coat, humidity is about 70%
bilge rat jim
  • Density: 10.3 lbs per gal
  • Tack Free Time: 60 min.
  • Rate of Cure: 1/4-in x 1/4-in bead 9 days at 40F/30% R.H.
    1/4-in x 1/4-in bead 4 days at 73F/50% R.H.
    1/4-in x 1/4-in bead 3 days at 73F/70% R.H.
    1/4-in x 1/4-in bead 1 day at 100F/75% R.H.
  • Shore A Hardness (ASTM D2240): 45-50
  • Elongation at Break (ASTM D412): >600%
  • Tensile Strength (ASTM D412): 221 PSI
  • Lap Shear Strength (ASTM D1002): 165 PSI
  • Peel Strength: 35 lbs/in on fiberglass, 25 lbs/in on gelcoat
  • Application Temperature: 40F to 110 F
  • Service Range: -40F to 190 F
  • Color: Black, White
  • Sandable, paintable and is waterproof
BoatFisho
So probably not the best choice for a keel protector needing quick attachment.
BoatFisho
I ended up peeling the keel protector as it had so many pockets and holes it wasnt worth it. I actually dont know what brand it was, couldnt recognise it against the major players otherwise I would have gone for the warranty. Thanks for the advise on sikaflex, i think it sounds a good option for fittings where you may one day want to remove them.
