silly carb??
Ron G
i woke up last night and started wondering.if ya fabricated those tiny tornadoes they use in cars to fit on the carbs of an outbord it should help alot but would ya have to do something to get more fuel or would just the little swirly things be alright?i know crazy but i think i can make some to work i must be crazy.d:)
guywithboat
Re: silly carb??
In theory it should work. I have also found a device on the net that can be used for any carburated engine that antomizes the fuel before it hits the carb. IT seemd to work like a nebulizer.
Silvertip
Re: silly carb??
Atomizes fuel before it hits the carb????? The carb is what atomizes the fuel. Why not add a magnet to the fuel line right away. Remember those? And you are staying awake over this junk? If it/any worked every engine would be fitted with them. The manufacturers would have a leg up on the competition. If you bolted on every device that supposedly increased fuel economy or enhanced performance you'd have to stop once an hour to drain off some fuel as the tank would run over. These are all gimicks.
JB
Re: silly carb??
What Silvertip said.
Ron G
Re: silly carb??
I wasnt staying awake i woke up and started wondering.i was watching on some hotrod show about the plates and things that sorta do the same thing.i said it was a silly ?now i know thanks.i can put that thought with my cold air system for outboards thoughtd:)
